Move around the OBS chart
You can change the level of detail that appears on-screen.
  • Click the Display Options bar and choose Zoom. You can zoom in, zoom out, or zoom to best fit.
Tip:
You can also use your mouse to control the level of detail that appears on-screen:
  • To zoom in, hold down the Alt key, click the background, and then drag the pointer down while holding down the mouse button.
  • To zoom out, hold down the Alt key, click the background, and then drag the pointer up while holding down the mouse button.
