Change the OBS chart information
  1. Choose Enterprise, OBS, then click the Display Options bar and choose Chart Box Template, Customize.
  2. Click Add.
  3. In the Field Name field, select a template element.
  4. Specify a width and height for the template element.
  5. Click the up and down arrows to place the element within the OBS box.
Tip:
  • To remove an element from the OBS box, select the element, then click Delete.
  • To revert to the default OBS box fields, click Default.
