Change user security profiles (P6 Professional Only)
  1. Choose Admin, Users.
  2. Select the user whose security profiles you want to change.
  3. To change a global profile, click the Global Access tab and select a new global profile.
  4. To change a project profile, click the Project Access tab. To remove the user's current access to project information associated with a specific responsible manager, select the manager, then click Remove. To grant the user access to project information associated with a specific responsible manager, click Assign. Double-click the OBS element to which you want to grant access, then click Close. To change the user's security profile for a project, double-click the security profile you want to change, then select a new project profile.
    While a user is working offline, changes to certain data can cause them not to be able to switch to working online. To ensure users who are currently working offline are not prevented from switching to working online, avoid making changing any of the following data if any user might currently be working offline: User details, Global or project security profiles, OBS assignments (both for users and for projects), and Resource security.
