Change user passwords (P6 Professional Only)
- Depending on your global profile, you may be able to change a user's password or your own.
- Choose Admin, Users.
- Select the General tab.
- Select the user who requires a change of password.
- Click Password.
- In the New Password field, enter the new password.
- In the Confirm New Password field, enter the password again, to verify it.
- Click OK.
- If the Enable password policy setting is selected in the Password Policy field of the Admin Preferences dialog box, enter a password that is a minimum of 8 characters long, and that contains one alpha and one numeric character.
- If the Enable password policy setting is not selected, enter a password up to 20 characters long.
- If P6 Professional is running in LDAP authentication mode, password management is handled through the directory server. You cannot change your password through the module and the Password button does not appear on the Users dialog box General tab.
- Passwords are case-sensitive.
- Passwords that were set before the new password policy was enabled are valid and usable.
