Enable or disable user access to P6 Professional (P6 Professional Only)
  1. Choose Admin, Users.
  2. Select the user for whom you want to enable or disable module access, then click the Module Access tab.
  3. In the Access column, mark or clear the checkbox for the modules you want to enable or disable for the selected user.
