Combine filters
You can combine existing filters to narrow your activity selection. Use any combination of default, global, layout, and user-defined filters. For example, combine the Critical and Milestone filters to view critical start and finish milestone activities in the layout.
- Choose Project, Activities, then choose View, Filter By, Customize.
- Mark the checkbox next to each filter you want to apply.
- Choose All or Any to determine how criteria are met.
- Click Apply to preview the results.
