Change a Gantt Chart bar's filter
  1. Choose Project, Activities, then display the Gantt Chart.
  2. Choose View, Bars.
  3. Select the Gantt Chart bar for which you want to change the filter. Double-click the Filter column.
  4. Mark the checkbox next to each filter you want to use.
  5. Click OK. To view your changes without closing this dialog box, click Apply.
