Compare budgets and variances
- Choose Enterprise, Projects, then click the Display Options bar and choose Columns, Customize.
- Select any budget-related columns you want to display in the Projects window.
For example, select the Project ID, Project Name, Original Budget, and Current Variance columns to compare the original budget amounts assigned to the projects, and the current variance resulting from budget spending on those projects to date.
When current spending differs from original budget estimates, a variance results. A variance amount shown in parentheses indicates a negative variance amount for the project.
