Print budget reports
You can print preformatted reports or create new reports to track budget amounts at the project and activity level.
- Choose Tools, Reports, Reports.
- Select the report you want to run, such as expense reports EX-01 through EX-05, which contain budget information.
- Click
on the Reports toolbar, or right-click on the report and choose Run, Report.
