Create a custom menu
You can create custom menus that contain only the commands you require for your work.
  1. Choose View, Toolbars, Customize. Opening the Customize dialog box switches the menus into Edit mode, which enables you to customize menus. You do not need to use the Customize dialog to customize menus; however, you must leave the dialog open to enable you to customize menus.
  2. Right-click any menu label.
  3. To edit the menu label, click in the Name field, highlight the existing name, then type a new name. For example, you could change the menu label to My Menu or My Commands.
  4. Customize your menu.
Tip:
You can revert to the default settings for all toolbars and menus.
