Customize a menu command
You can individually customize menu commands in the module. To customize a command:
- Choose View, Toolbars, Customize. Opening the Customize dialog box switches the menus into Edit mode, which enables you to customize commands. You do not need to use the Customize dialog to customize commands; however, you must leave the dialog open to enable you to customize commands.
- Click the menu label that contains the command you want to customize, then right-click the command.
- In the menu, do any of the following to customize the selected command:
- To edit the command's name, click in the Name field, highlight the existing name, then type a new name.
- To add a separator before the command in the menu, choose Begin a Group.
- When you are finished customizing commands, click Close in the Customize dialog box.
Tip:
From the command right-click menu, you can also do the following:
- To reset the selected command to its default settings, choose Reset.
- To delete the selected command, choose Delete.
