Create a Project Table
A Project Table displays nontimescaled project data in a row and column format. When you first create a table, you are prompted to select the columns included in the table and uses default settings for all other layout elements. You can change these other elements after the layout is created.
  1. With the Tracking window active, choose View, Layout, New. You can also click the Display Options bar in the Top Layout window and choose Layout, New.
  2. Type the new layout's name.
  3. Select the users who will be able to access the layout: Current User or All Users.
  4. Choose Project Table, then click OK.
  5. To accept the columns automatically included in the table, which are the earned value fields, click OK.  - Or - In the Available Options section, click each column you want to include, while holding down the Ctrl key, then click
    .To remove a selected column, select it in the Selected Options section, then click
  6. To change the title, width, and alignment of a column, select the item in the Selected Options section, then click Edit Column.
  7. Type a new title, specify a new width (in number of characters), and choose an alignment. Click OK.
  8. To preview your Project Table column selections without closing the Columns dialog box, click Apply.
