Project Table layouts
In the Tracking window, a Project Table displays project data in a row-and-column format. You can specify which columns you want to include in the table. The rows displayed correspond to your selection in the Project Explorer window and the current group and sort option. You can group by project, EPS/WBS, OBS, phase, or by specific WBS data, and sort by any WBS-level column. You can show grand totals and/or summary data only. In addition, you can create filters to more narrowly define the information you see.
