Create risk categories (P6 Professional Only)
You can create hierarchical risk categories of possible risks that you can assign to risks. Risk categories are a classification of risk types customized to your specific project or business that are used to categorize and organize risks. Categorizing risks enables you to analyze the types of risks occurring and see trends within the project or across multiple projects.
- Choose Admin, Admin Categories.
- Click the Risk Categories tab, then click Add.
- Type the name of the new risk category.
Tip:
To change the hierarchical order in which risk categories are listed, select the risk category you want to move, then click Shift up, Shift down, Shift Right, or Shift Left, as applicable.
