Edit risk categories (P6 Professional Only)
- Choose Admin, Admin Categories.
- Click the Risk Categories tab.
- Double-click the category you want to change, then enter the new risk category name.
Tip:
- To change the hierarchical order in which risk categories are listed, select the risk category you want to move, then click Shift up, Shift down, Shift Right, or Shift Left, as applicable.
- If you change a risk category, your change applies to all risks assigned that category.
