Customizing toolbars
The module provides customizable toolbars that enable you to quickly access all available windows, dialog boxes, and associated functionality. You can:
  • Show or hide toolbars
  • Show or hide toolbar icons
  • Move toolbars
  • Move toolbar icons
  • Lock toolbars in position
  • Delete icons from toolbars
  • Set toolbar display options
  • Customize a toolbar icon
  • Create a custom toolbar
Tip:
The state of your toolbars is saved each time you close the module. To undo all changes to toolbars, you can reset toolbars to restore them to the factory default settings.
