Show or hide toolbars
Many toolbars display by default; however, some additional toolbars are available for you to display. For example, you can display a Reports toolbar if you routinely produce reports.
To show or hide an individual toolbar:
  1. Right-click anywhere in the toolbar area or choose View, then point to Toolbars.
  2. Select the toolbar you want to show or hide. A checkmark next to the toolbar name indicates that it is currently displayed. After selecting the toolbar you want to show or hide, the menu closes.
To show or hide multiple toolbars:
  1. Choose View, Toolbars, Customize.
  2. On the Toolbars tab, mark the checkbox next to each toolbar you want to display, and clear the checkbox next to each toolbar you want to hide.
  3. Click Close.
Tip:
You can revert to the default settings for an individual toolbar, or for all toolbars.
