Show or hide toolbar icons
Although some icons display on toolbars by default, you can show or hide any icon on any displayed toolbar.
  1. For toolbars displayed horizontally, click the black triangle on the right side of the toolbar you want to customize.
    For toolbars displayed vertically, click the black triangle at the bottom of the toolbar you want to customize.
  2. Point to Add or Remove Buttons.
    The menu that appears lists the icons for the toolbar, in the left-to-right or top-to-bottom order in which they appear in the row or column.
  3. Choose each icon you want to show or hide.
    The menu remains open while you select icons. A checkmark indicates the icon is currently selected for display.
  4. Click anywhere outside the menu to close it.
Tip:
You can revert to the default settings for an individual toolbar, or for all toolbars. To reset an individual toolbar, choose Reset Toolbar in the menu you used in this procedure.
