Cut and paste an OBS element
  1. Choose Enterprise, OBS.
  2. Click the OBS Name column label to display the OBS hierarchy.
  3. Select the OBS element you want to cut and paste, then click Cut.
  4. Select the OBS element to which you want to add the cut OBS element, then click Paste.
