Copy and paste an OBS element
- Choose Enterprise, OBS.
- Click the OBS Name column label to display the OBS hierarchy.
- Select the OBS element you want to copy, then click Copy.
- Select the OBS element to which you want to add the copied OBS element, then click Paste.
