Edit an OBS element
  1. Choose Enterprise, OBS.
  2. Click the OBS Name column label to display the OBS hierarchy.
    The outline symbol "" in the OBS Name column label indicates a hierarchy display.
  3. Select the OBS element you want to edit.
  4. To change the element's information, click the General tab and enter new information.
  5. To change the element's position in the OBS, click the appropriate arrow buttons.
