Delete an activity
- Choose Project, Activities.
- Select the activity you want to delete, then choose Edit, Delete.
- Click Yes to confirm that you want to delete the selected activity.
Tip:
To remove an activity, but maintain the relationship between its predecessor and successor activities, dissolve the activity instead of deleting it.
