Designating an activity owner (P6 EPPM Only)
You can designate users as activity owners. An Activity Owner who has Projects module access to P6 (assigned using P6) and has the required privileges can update the activity's status and other details. Follow this procedure to designate a user as an activity owner.
Display the Owner Column
  1. With the Activities window active, choose View, Columns.
  2. In the Available Options list, expand the General category.
  3. Locate the Owner field, highlight it and then click "" to move it to the Selected Options field.
  4. Click OK.
Designate an Activity Owner
  1. In the Activity Table of the Activities view, double click the appropriate activity under the Owner column.
  2. Highlight the appropriate user and click Select.
