Delete a threshold
  1. Choose Project, Thresholds.
  2. Select the threshold, then choose Edit, Delete.
  3. Click Yes.
    If you delete a threshold, historical issue data are also deleted. If you disable a threshold, new issues are not generated for it, but historical issue data are maintained.
