Disable or enable a threshold
  1. Choose Project, Thresholds.
  2. Select the threshold, then double-click in the Status column and select Disabled or Enabled.
    A disabled threshold does not generate new issues, but historical issue data are maintained. If you delete a threshold, historical issue data are also deleted.
