Delete global activity code values
- Choose Enterprise, Activity Codes.
- Choose Global.
- Select the code whose value you want to delete.
- Select the value you want to delete, then click Delete.
- Click Yes.
When you delete a global activity code value, all activity assignments made to that activity code value are automatically deleted.
