Delete global activity codes
  1. Choose Enterprise, Activity Codes.
  2. Choose Global, then click Modify.
  3. Select the code you want to delete, then click Delete.
  4. Click Yes.
    When you delete a global activity code, all code values associated with the deleted activity code and all activity assignments to those activity code values are automatically deleted.
