Edit color of global activity code value
Colors assigned to activity code values are used only in Visualizer drawings.
This procedure assumes you have already created an activity code value for which you want to edit a color.
- Choose Enterprise, Activity Codes.
- Choose Global.
- Double-click the cell under the Color column for the applicable activity code value. This launches the Color dialog box. When you complete that dialog box, click OK.
- Click Close.
- The Color column is disabled for Global activity Codes if you do not have "Edit Global Activity Codes" global privilege.
- The Color column is disabled for secure codes if you do not have "Edit Secure Codes" global privilege.
- To remove color from an activity code value, launch the Color dialog box and assign the color white.
