Edit global activity code values
- Choose Enterprise, Activity Codes.
- Choose Global.
- Select the activity code whose value you want to change. To change a value name or description, double-click the item you want to change, then type the new text. To change the placement of the code in the list, click Shift Up or Shift Down.
- Click Close.
Tip:
If you change an activity code value, your changes apply to all activity assignments.
