Edit global activity codes
- Choose Enterprise, Activity Codes.
- Choose Global, then click Modify.
- Select the activity code you want to edit. To change the activity code's name, type a new name. To change the maximum number of characters the code's values may have, specify a new number. To change the placement of the code in the list, click the appropriate arrow.
- Click Close.
Tip:
If you change an activity code, your changes apply to all activity assignments.
