Display past period actuals in a profile
- In the Tracking window, display the profile in the Bottom Layout window, click the Display Options bar, then choose Bottom Layout Options, Profile Settings.
- Click the Data tab.
- In a project profile, mark the Display Actual and Earned Value using Financial Period data option.
In a resource profile, mark the Display Actual using Financial Period data option.
If projects are summarized by financial period (which is controlled by an administrative setting), the financial period profile setting is ignored. When projects are summarized by financial period and you display a financial period timescale, the profile displays past period actual values if performance has been stored for a financial period; for financial periods that do not have stored performance, the profile displays actual to date values stored in financial period intervals.
