Show or hide resource overtime in a profile
You can view resource overtime, in a regular histogram,only when displaying the resource profile for selected projects, not in the total allocation resource profile.
- Display the profile in the Top Layout window, then click the Display Options bar in the profile and choose Top Layout Options, Profile Settings.
You can also click
in the Top Layout window toolbar. - Click the Data tab.
- In the Additional Data Options area, mark or clear the Show Overtime checkbox.
