Enter email settings
You can access your email account to send email messages.
- Choose Edit, User Preferences.
- Click the email tab.
- Select the mail protocol for your email system.
- In the Profile Name field, type the profile name, login, or username you use to access your email server.
Click Password, then type the password associated with the selected profile name.
- In the Outgoing Mail Server (SMPT) field, type the SMTP server name or address to use to send outgoing email.
- In the Security list, select the security protocol required to access the SMTP server.
- Type the SMTP Port number for the SMTP server.
- Optionally, in the User Name field, type the user name from which to send email.
If you type a user name, click Password and enter the password associated with the selected user name.
- Optionally, in the User Email Address field, type the email address to which you want your return email sent.
If you do not enter a return email address, all email is returned to the address you used to send the email.
