Set wizard options
You can specify whether you want wizards to help you add activities and resources.
  1. Choose Edit, User Preferences.
  2. Click the Assistance tab.
  3. To use the New Resource wizard, mark the Use New Resource Wizard checkbox.
  4. To use the New Activity wizard, mark the Use New Activity Wizard checkbox.
