Change my password
- Choose Edit, User Preferences.
- Click the Password tab.
- Click Password.
- Type a new password.
The rules governing passwords depend on which type of database you are connected to and how certain settings are configured. See the tip below for further information.
- The rules for pass
- Type the password again to verify it.
- Click OK.
Tip:
When P6 Professional is running in LDAP authentication mode:
- Password management is handled through the directory server.
- You cannot change your password through P6 Professional and the Password tab does not appear in the User Preferences dialog box.
When P6 Professional is connected to a Cloud Connect database:
- Password management is handled through P6.
When P6 Professional is connected to a Standalone or PPM database:
- If Enable password policy is enabled in the Password Policy field of the Admin Preferences dialog box, you must enter a password that is between 8 and 20 alphanumeric characters and contains at least one number and one letter.
- If Enable password policy is disabled, your password must be between 1 and 20 alphanumeric characters long.
When P6 Professional is connected to a P6 EPPM database:
- When the Password Policy is enabled in Application Settings in P6, the password must be between 8 and 20 alphanumeric characters and contain at least one number and one letter.
- When the Password Policy is disabled in Application Settings in P6, the password must be between 1 and 20 alphanumeric characters.
- P6 does not allow blank passwords.
- Passwords are case-sensitive.
- Passwords that were set before the new password policy was enabled are valid and usable.
- Passwords are required.
