Set startup options
You can specify the window you want to display each time you start the application.
  1. Choose Edit, User Preferences.
  2. Click the Application tab.
  3. In the Startup Window section, select the window to display each time you start the module.
  4. Mark the Show the Issue Navigator Dialog at Startup checkbox to view the Issue Navigator each time you open the module.
  5. Mark the Show the Welcome Dialog at Startup checkbox to view the Welcome dialog box each time you open the module.
