Enterprise Menu
Enterprise Menu (Alt+N)
Command Function Enabled when active window is: Corresponding toolbar
Projects Opens the Projects window. Use the Projects window to set up the EPS, add new projects, and manage multiple projects. All Enterprise Toolbar
Enterprise Project Structure
This command appears only when P6 Professional is connected to a P6 Professional database.
Opens the Enterprise Project Structure (EPS) dialog box. Use the Enterprise Project Structure (EPS) dialog box to define the EPS - the hierarchical structure of your database of projects.
Tracking Opens the Tracking window. Use the Tracking window for monitoring a project's progress using different types of layouts. All Enterprise Toolbar
Project Portfolios Opens the Project Portfolios dialog box. Use the Project Portfolios dialog box to add, edit, and delete portfolios. All Enterprise Toolbar
Resources Opens the Resources window. Use the Resources window to maintain both your organization's resource hierarchy and individual resource information. All Enterprise Toolbar
Roles Opens the Roles dialog box. Use the Roles dialog box to add, edit, and delete roles. You can also use the Roles dialog box to assign roles to resources, define up to five price/unit rates for each role, and specify role availability over time. All Enterprise Toolbar
OBS
Opens the Organizational Breakdown Structure dialog box. Use the Organizational Breakdown Structure dialog box to create, view, and edit the organizational breakdown structure (OBS). You can also use this dialog box to view a list of users who can access an OBS element's project information.
Resource Codes Opens the Resource Codes dialog box. Use the Resource Codes dialog box to create, edit, and delete resource codes. You can use these codes to sort, filter, group, and report on project data across the enterprise. All Dictionaries Toolbar
Role Codes Opens the Role Codes dialog box. Use the Role Codes dialog box to create, edit, and delete role codes. You can use these codes to sort, filter, group, and report on project data across the enterprise. All Dictionaries Toolbar
Project Codes
Opens the Project Codes dialog box. Use the Project Codes dialog box to create, edit, and delete global and project codes and values. Use these codes and values to sort, filter, group, and report activity information.
Activity Codes
Opens the Activity Codes dialog box. Use the Activity Codes dialog box to create, edit, and delete global, project, and EPS activity codes and values. Use these codes and values to sort, filter, group, and report activity information. You can also use this dialog box to assign colors to activity code values, applicable only in the context of Visualizer drawings, to activity code values.
See Activity codes and values for more information.
User Defined Fields Opens the User Defined Fields dialog box. Use the User Defined Fields dialog box to add an unlimited number of custom fields and values to the project database. All Dictionaries Toolbar
Calendars Opens the Calendars dialog box. Use the Calendars dialog box to create, edit, and delete global, project, and resource calendars. You can also view calendar assignments, and you can specify a default global calendar. All Dictionaries Toolbar
Resource Shifts Opens the Resource Shifts dialog box. Use the Resource Shifts dialog box to define shift calendars for resources. All Dictionaries Toolbar
Activity Step Templates
Opens the Activity Step Templates dialog box. Use the Activity Step Templates dialog box to create templates containing groups of steps common to multiple activities. You can then assign these templates to activities.
Cost Accounts
Opens the Cost Accounts dialog box. Use the Cost Accounts dialog box to maintain your organization's cost accounts. You can assign these cost accounts to activities in any project.
Funding Sources
Opens the Funding Sources dialog box. Use the Funding Sources dialog box to set up a funding sources dictionary containing any non-profit, government-allocated, or other funding sources for easy assignment to budget items.
Stored Images Opens the Images Manager dialog box. Use the Pictures dialog box to upload pictures to the database for use in reports. All None
Resource Curves Opens the Resource Curves dialog box. Use the Resource Curves dialog box to add, delete, or modify resource curves. Curves are used to allocate resources and costs over the duration of an activity. All Dictionaries Toolbar
External Applications Opens the External Applications dialog box. Use the External Applications dialog box to set up links with external applications. All None
