Enterprise Toolbar
Use the Enterprise toolbar to access windows and dialog boxes in which you can view, add, edit, and delete enterprise-level data, such as the EPS, resources, roles, and reports. This toolbar is displayed by default.
The following table provides information about each available icon on the toolbar.
Icon Function Displays by default? Corresponding menu command
Opens the Projects window.
When connected to a P6 Professional database: Use the Projects window to set up the EPS, add new projects and manage multiple projects.
When connected to a P6 EPPM database: Use the Projects window to add new projects and manage multiple projects.
Yes Enterprise > Projects
"" Opens the Resources window. Use the Resources window to maintain both your organization's resource hierarchy and individual resource information. Yes Enterprise > Resources
"" Opens the Reports window. Use the Reports window to create, edit, run, delete, import, and export global and project reports. Yes Tools > Reports
"" Opens the Tracking window. Use the Tracking window for monitoring a project's progress using different types of layouts. Yes Enterprise > Tracking
This icon appears only when P6 Professional is connected to a P6 Professional database.
Opens the Enterprise Project Structure (EPS) dialog box. Use the Enterprise Project Structure (EPS) dialog box to define the EPS—the hierarchical structure of your database of projects.
No Enterprise > Enterprise Project Structure
"" Opens the Project Portfolios dialog box. Use the Project Portfolios dialog box to add, edit, and delete portfolios. No Enterprise > Project Portfolios
"" Opens the Roles dialog box. Use the Roles dialog box to add, edit, and delete roles. You can also use the Roles dialog box to assign roles to resources, define up to five price/unit rates for each role, and specify role availability over time. No Enterprise > Roles
Opens the Organizational Breakdown Structure dialog box. Use the Organizational Breakdown Structure dialog box to create, view, and edit the organizational breakdown structure (OBS). You can also use this dialog box to view a list of users who can access an OBS element's project information.
No Enterprise > OBS
Tip:
  • To show icons on the toolbar that do not display by default, you must customize the toolbar.
  • The icons in this toolbar are always enabled.
  • The icons on this toolbar do not have corresponding shortcut keys.
