Find Toolbar
Use the Find toolbar to search for and replace values you specify in the active window.
By default, this toolbar is not displayed.
The following table provides information about each available icon on the toolbar.
Icon Function Shortcut keys Corresponding menu command
Opens the Find dialog box. In this dialog box, you can search for a value you specify in the active window.
Tip In windows that can display multiple views simultaneously (for example, a table and chart), before you start the search, you must select an object in the area of the window in which you want to conduct the search.
Ctrl+F Edit > Find
"" Finds the next occurrence of the search criteria you previously entered in the Find dialog box. F3 Edit > Find Next
"" Replaces text found in search results with new text you specify. Ctrl+R Edit > Replace
Tip:
All of the icons on this toolbar display by default when you choose to show the toolbar.
