Export a tracking layout
  1. Choose View, Layout, Open. You can also click the Display Options bar in the Layout window and choose Layout, Open.
  2. Select the layout you want to export, then click Export.
  3. Specify the drive and folder to which you want to export the layout, type a name for the layout, then click Save. The layout is saved in Primavera Layout File (. PLF) format.
