Save a tracking layout
  1. Choose View, Layout, Save or Save As. You can also click the Display Options bar in the Layout window and choose Layout, Save or Save As.
  2. If you choose Save As, type a new name for the layout and indicate whether the layout should be available to All Users, the Current User, or Another User. If you select Another User, click "" in the User field, then select the user.
