Filter resources in the Resource Explorer window
  • Click the Display Options bar in the Resource Explorer window, then choose Filter By and one of the options listed below.
View by Resource
All Active Resources: Displays all resources assigned in the enterprise.
All Resources: Displays all resources defined for the enterprise.
Current Project's Resources: Displays resources assigned to the project currently selected in the Project Explorer window.
Customize: Enables you to specify how you want to filter resources.
View by Role
All Roles: Displays all roles defined for the enterprise.
Current Project's Roles: Displays roles assigned to the project currently selected in the Project Explorer window.
Customize: Enables you to specify how you want to filter roles.
