Group and sort resources in the Resource Explorer window
  1. To view by resource, in the Resource Explorer window, click the Display Options bar and choose Select View, By Resource.
  2. Click the Display Options bar again, then choose Group and Sort By and choose Default to show resources by level, List to show resources in a flat list, Primary Role to show resources grouped by their primary role, or Customize to specify more detailed group and sort options.
Tip:
When you group resources by resource code or primary role, the resource profile displays a total for the code or role, as well as for each resource assigned to the code or role.
