Global and project privileges for EPS-level activity code security (P6 Professional Only)
Only users with the appropriate combination of secure code and global EPS-level activity code privileges can add, edit, delete, view, and assign "secure" EPS-level activity codes and values.
- To limit the access of a specific EPS-level activity code and its values to certain users, mark the Secure checkbox for the code in the Activity Code Definitions - EPS dialog box. You must have the Add EPS Activity Codes project-level security privilege and the Add and Delete Secure Codes global security privilege to set up a secure code.
- To add a secure EPS-level activity code in the Activity Code Definitions - EPS dialog box, you must have the Add EPS Activity Code project security privilege, and the Add and Delete Secure Code global security privilege.
- To edit a secure EPS-level activity code in the Activity Code dictionary, you must have the Edit EPS Activity Code project security privilege, and the Add and Delete Secure Codes or Edit Secure Codes global security privileges.
- To delete a secure EPS-level activity code from the Activity Code dictionary, you must have the Delete EPS Activity Code project security privilege, and the Add and Delete Secure Codes global security privilege.
- To assign and remove EPS-level activity code values to/from an activity you have access to, you must have the project security privilege to Add/Edit Activities Except Relationships and access to the activity. Activity access is based on the OBS security settings.
- To assign or remove a secure EPS-level activity code to or from an EPS in the Activity Codes dictionary, you must have the Add/Edit Activities Except Relationships project security privilege, and the Assign Secure Codes global security privilege.
