Set up security for EPS-level activity codes (P6 Professional Only)
The EPS-level activity codes that a user has access to is based on their project access. Do the following to set up user security:
- Set up the OBS security.
- Set up the EPS structure and select the responsible manager (OBS name) for the EPS level. The EPS levels the user can access is based on the OBS selected.
- Assign a project profile to the user. The project profile determines the privileges for all aspects of a project.
