Importing Options -- Projects
If resource security is enabled (you have limited or no resource access), the following restrictions apply when importing activity resource assignments:
- If Project Import option is Create New Project, Update Existing, Replace Existing or Add into Existing Project:
- If Global Resource option is set to Do Not Import: For new resources, no activity resource assignment data is imported. For existing resources, the Activity Resource Assignments project option determines how the data is imported.
- If Global Resource option is set to Keep Existing, Update Existing, or Insert New: For new resources, activity resource assignment data is imported only if you have limited or all resource access (but not "no resource access"). And those resources are imported only if they are in your resource node. For existing resources, the Activity Resource Assignments project option determines how the data is imported.
- If Project Import option is Ignore this Project:
- No activity resource assignment data is imported.
If you have no resource access, you cannot import activity resource assignments if the resource does not exist in the resource dictionary.
