Menu bar
Use the Menu bar to access all available functionality in the module. You can change the location of the Menu bar, and you can customize the commands that appear in each menu. You can not hide the Menu bar.
The following tables list the commands available in each menu, provide a brief description of each command's function, and list the active windows in which the command is enabled. For menu commands that have corresponding icons, the tables list the toolbars on which the corresponding icons are located.
The Menu bar contains the following menus:
  • File Menu
  • Edit Menu
  • View Menu
  • Project Menu
  • Enterprise Menu
  • Tools Menu
  • When connected to a P6 Professional database: Admin Menu
  • Help Menu
Tip:
The icons and shortcut keys, if any, associated with each menu command are displayed next to the commands in each menu.
