Move Toolbar
Use the Move toolbar to move the selected object around in hierarchy views. This toolbar is displayed by default.
The following table provides information about each available icon on the toolbar.
| Icon | Function |
| Moves the selected object up one row in the hierarchy. | |
| Moves the selected object down one row in the hierarchy. | |
| Moves the selected object to the left in the hierarchy. Moving an object to the left moves it up to the next level in the hierarchy. | |
| Moves the selected object to the right in the hierarchy. Moving an object to the right moves it down to the next level in the hierarchy. |
Tip:
- All of the icons on this toolbar display by default.
- The icons on this toolbar do not have corresponding shortcut keys or menu options.
