Preview Global Change in a report
  1. Choose Tools, Global Change.
  2. Click New.
  3. Define If, Then, and Else statements to specify the data you want to change.
  4. Click Change. A Global Change Report displays in the Global Change Report dialog box.
  5. Select the rows to apply to your data.
  6. To save the report, click Save to File and type a name for the report. The report saves as an ASCII document.
  7. To accept the changes, click Commit Changes; to cancel the Global Change and return the data to its original state, click Cancel Changes.
