Search for blank fields
You can use Global change to search for blank fields.
  1. Choose Tools, Global Change.
  2. Click New, or select an existing specification and click Modify.
  3. In the If section, specify a data item in the Parameter field.
  4. Specify a criteria in the Is field.
  5. Type " " (two quotation marks separated by a space) in the Value field.
